I am performing a clean install of JobMonster on my site, which is not yet in operation but has been in testing environment with various plugins. All required plugins were installed successfully. After initial setup going through all main admin tabs within JobMonster, I navigated to Companies within Jobs on main WP admin left panel. On the Companies admin page, the dropdown menu there is populated with selections that appear to be sourced from Yoast SEO plugin which is installed and activated but not yet configured.
How can I correct this issue without corrupting Yoast SEO? If I uninstall Yoast SEO, populate Companies, then re-install Yoast SEO, will the same thing happen again?
