I have to contact you again because there is a problem with the custom fields. Please help as soon as possible as it affects several jobs. The field to close the job does not update. It stays on the old date and you cannot apply. It should be set to March 28, 2025. Now nobody has been able to apply for some time because everything is so unstable.
In between, fields simply drop out without us having done anything to the FSystem. I can't check everything every day to make sure it's still running smoothly. Why is that?
Please help quickly with the closing date of the jobs! This is very misleading, as the current date is then in the field, but the old date remains in the calendar.
You still have the accesses. Please check here immediately.
