NooTheme Premium WordPress Theme › Forums › Timetable › Class level monthly shows all timetables
- This topic has 7 replies, 2 voices, and was last updated 4 years, 10 months ago by
BWebDesign2015.
4 years, 10 months ago #1212941
So if you go here: https://theamethystcave.co.uk/southbourne-cave-timetable/ May its fine but as soon as you go to June Southbourne calendar is showing both: Milton and Southbourne, this is the shortcode we are using:
[ntt_schedule default_view="month" item_limit="0" max_time="0:00:00" filter_type="level" class_level="54" class_show_icon="no" show_filter="no" show_weekends="sat,sun" class_item_style="cat_bg_color" general_header_background="#720067" general_today_column="#fff" general_navigate_link="external" show_category="no"] as you can see i am using: filter_type="level" class_level="54" but it does not seem to be properly working.
Aaron4 years, 10 months ago #1212943Dear, please kindly send for me admin account your site via private reply, I will check details problem on your site to help you.
4 years, 10 months ago #1212952This reply has been marked as private.4 years, 10 months ago #1212953Dear, what is 'Milton and Southbourne' Please kindly give me more details with screensho. I will check to help you.
4 years, 10 months ago #1212957Hi,
So New Milton is a Level and Southbourne Cave are Levels. both 2 different Levels example:
4 years, 10 months ago #1212960Had to do another post as would only allow 2 screenshots
and then if you go here:
and
https://theamethystcave.co.uk/new-milton-cave-timetable-2/
Your see when go to like June etc, both are showing some of the wrong Classes based on Level, so Southbourne Cave has New Milton in it. and vice versa.
Aaron
4 years, 10 months ago #1212965Dear, Please kindly update Noo Timetable plugin on your site to latest version 2.1.3 and check again. Your problem is fixed in plugin latest version.
4 years, 10 months ago #1212966Thankyou,
That seems to of fixed it.
Aaron
