NooTheme Premium WordPress Theme › Forums › JobMonster › Change link color
- This topic has 12 replies, 2 voices, and was last updated 6 years, 8 months ago by
6 years, 11 months ago #1072825
Hello support,
the links in the blog posts have the same color as the text itself. Can you please let me know how I can change that to the default color of the site please?
Thank you!
6 years, 11 months ago #1072845
Do you want to focus blog page or single blog page? Please confirm us again then give us your website's URL.
We will help you to check it.
6 years, 10 months ago #1074633This reply has been marked as private.6 years, 10 months ago #1074660
Please try to add this Custom CSS segment to Customizer > Additional CSS:
div#ez-toc-container ul.ez-toc-list a{color: #2dbb7a !important;}
P.S change your suitable color.
6 years, 9 months ago #1075665Hi Tracy,
thank you but I did want to change the TOC link colors.
I would like to change the normal ahref internal links to other pages to the default color of the site. Can you please help?
Thank you!
6 years, 9 months ago #1075667
Can you provide us an image to describe the exact section you want to change? We will check it.
6 years, 9 months ago #1075802This reply has been marked as private.6 years, 9 months ago #1075804This reply has been marked as private.6 years, 9 months ago #1075819
We are so sorry but you cannot change the link color for each part individually as your desired.
6 years, 8 months ago #1076601Hi Tracy,
I want to change all the link colors inside posts (not individually).
Previously you gave me this code:
This changes the color of the TOC(table of contents) - I want to change the normal internal links inside every post to a different color.
Is that really not possible?
6 years, 8 months ago #1076615
yes, because Jobmonster provided a general code structure for the blog post. For example, the link will be written by "a"element. Therefore, it will be changed the total page not only each part.
6 years, 8 months ago #1076619Ok I see.
Is there any chance you will change it in the near future? Readers of the blog post does not know if there is a link in the text, so that they don't navigate over to other pages and that hurts SEO a lot.
Thank you!
6 years, 8 months ago #1076659
We will discuss with our developer about it. However, this theme mostly focuses the Job and Resume so if you want to change more, please find the freelancer developer to help.
We are so sorry for this inconvenience and thanks for your understanding.
