NooTheme Premium WordPress Theme › Forums › JobMonster › Carousel causes screen to move to top of page on slide change
- This topic has 3 replies, 2 voices, and was last updated 3 years, 11 months ago by
3 years, 12 months ago #1219388
As the title says when the slider changes the screen is forced to move back to the top of the page when setting a image slider (slideshow) as a background for "Advanced Search". Please see the attached. You have to still stay on the slider for example half way scroll down but still on the slider image and wait till the slider image changes to next. The screen moves to the top of the page when it happens. To see it, you may have to have the Advanced Search at the top of the page like your demo content.
This bug I think is something to do with jQuery carouFredSel 6.2.1 but the plugin has the latest code. The author hasn't released a newer one. I found the article that could be related but don't know how to modify and test the code.
This is the reason why I wanted to use Revolution Slider instead but setting the revolution slider (as a background of advanced search) makes the Advanced Search Setting uneditable after publishing/updating the page. I mentioned this in another query post.
I hope my explanation makes sense.
I am hoping to get your support for this and others soon. I know you are busy but my continuous posts will not continue forever. It will finish one day soon. Now I am in the phase of testing the theme to learn what can, how can and cannot be done in the project.
Thank you for your patience and understanding.
3 years, 11 months ago #1219405Hi.
Thank you for your feedback.
We have checked and fixed that issue with the revolution slider background type.
3 years, 11 months ago #1219410Yes, now revo slider can be used as an alternative thanks to you.
So I don't need to use image slider.I can close the ticket but maybe you may want to keep it open because it still is a theme bug.
Unless you remove image slider from the option, some users still want it fixed.3 years, 11 months ago #1219429Yes, I will update the theme to fix that issue for another customer.
