NooTheme Premium WordPress Theme › Forums › JobMonster › Candidates can't place resume
- This topic has 19 replies, 2 voices, and was last updated 6 years ago by
6 years, 1 month ago #1083315
Like the title suggest:
6 years, 1 month ago #1083321Hi,
Please send me a screenshot to clarify
6 years, 1 month ago #1083353This reply has been marked as private.6 years, 1 month ago #1083369Hi,
If you want to use the package, you will have to select "Candiate with Paid Package" for "Maak een visitekaartje".
If you only enable on these options, it will not work:
6 years, 1 month ago #1083388I do not want people to use a package for being able to place a resume, that is why the option is set to 'Candidates'.
6 years, 1 month ago #1083389And apply job have to be for a paid package. Why you've changed that back?
6 years, 1 month ago #1083398Why you have both options if both have to be set to the same?
6 years, 1 month ago #1083412Hi,
It seems I mentioned this issue to you on a previous topic:
Our package revolves around posting a job or posting a resume. If you want to use the package, you will have to use the package for these two options.
With other options, you can use the package or not (Apply a job is one of them.)
6 years, 1 month ago #1083431So what that means? I want no package to for posting resume, I want package for reaction on a job. You have in your theme those 2 options separated but they don't work separated? So why they are optional than? And in other topic it was about Job reacting so now I have hired a programmer to only forgot payment after reacting. And now this whole theme don't work. Because u have two options that work in in 1 direction, in plain English: 2 option but only work if you select both equal? How retarded af is that?
6 years, 1 month ago #1083435Hi,
The package here is for Posting Resume only.
- With this option:
Only users who purchase the Posting Resume package can apply Job.
6 years, 1 month ago #1083438Then why you have 2 options? Why u can set them different if they don't matter at al.
6 years, 1 month ago #1083441So this dropdown button is for fun to play with or what exactly and how do I prevent that I cannot POST A RESUME LIKE I AM ASKING A MILLION TIME WITHOUT HAVING THE PACKAGE LIKE THE OPTION SUGGEST.
6 years, 1 month ago #1083443wow what a great support actually by canceling out the code that prevents it from happening
root-folder: page-post-resume.php
/* if( !jm_can_post_resume() ) {noo_message_add(__('Sorry, you can\'t post resume.', 'noo'),'error');if( jm_check_package_post_resume() && Noo_Member::is_candidate()){jm_force_redirect(Noo_Member::get_endpoint_url('manage-plan'));}else{jm_force_redirect(Noo_Member::get_member_page_url());}} */6 years, 1 month ago #1083662So now after my comments I presume in this toppic, with the update nothing works anymore and greyed out the 2nd option? Oh yes by the way 22nd to 30th Jan no support do I get extra time for support of 8 days extra after support is expired?
6 years, 1 month ago #1083793Hi,
Sorry for the delayed reply.
We just came back from the Lunar New Year holidays.
As I mentioned earlier: In Jobmonster, packages are used for Post a Job and Post a Resume.
Then there are a few additional options when the package is turned on.
- As in your case:
Apply a Job with Candidate with paid package will not work when the resume package has not been activated on "Post Resume".
(That is, the Apply Job package does not work independently, it is only an option in the Resume Package.
So we have disabled the Package option on "Apply Job" if "Resume Pakage" is not enabled to avoid misunderstandings for users.
-- In your case, you can do the following:
1, Enable Resume Package:
2, You create a Resume Package with:
- Resume Posting limit : Unlimited Posting. http://prntscr.com/qwnedv
- Checkbox to "Can apply for Job" and set Job apply limit
6 years, 1 month ago #1083809But that also means they still have to buy that (like ordering... want too prevent that actualy) ? And in my other toppic not getting mails anymore, why is that?
6 years, 1 month ago #1083811Yeah right, other moment waiting forever for my awnser .... this is not helping business but molesting it.
6 years, 1 month ago #1083867Sorry about this, Jobmonster currently has no independent run package for "Apply for Job".
6 years ago #1084628We've changed a lot of the code, by now. It seem's working. Still other question in my other toppic really need that too be solved. Kind of a major issue.
6 years ago #1084657Hi,
I answered your topic.
