NooTheme Premium WordPress Theme › Forums › JobMonster › bulk delete jobs
- This topic has 12 replies, 2 voices, and was last updated 5 years, 1 month ago by
5 years, 2 months ago #1210875
can you please explain how can I delete/trash all the jobs at once.
5 years, 2 months ago #1210890Dear, You want delete all job on backend admin or on fronend job board ?
5 years, 2 months ago #1210900Hi,
I want to delete on both sides, front end also back end.
Please advice.
5 years, 2 months ago #1210967Dear, I check again, i see the Jobmonster is support bulk action to delete job and on admin you can check all jobs to use bulk action to delete job. Please check again.
5 years, 2 months ago #1211019Hi,
Can you tell me where is the bulk delete option please?
5 years, 2 months ago #1211020Hi,
There is move to trash option but there is no select all option that I can see.
Can you please send me a screenshot of where is select all jobs option to delete it please.
5 years, 2 months ago #1211076Dear, To delete Job, you need move to trash then delete permanently Job in Trash (See attachment)
But if you want show 'Delete permanently' in bulk actions without move to trash. Please kindly read this article to add menu delete in bulk actions.
5 years, 2 months ago #1211260This reply has been marked as private.5 years, 2 months ago #1211329Sorry, the Jobmonster not support any to help you do it. You can use plugin to bulk delete all job:
eg:https://wordpress.org/plugins/bulk-delete/
5 years, 2 months ago #1211362Hi,
I have installed the above 3 plugins, can you help me to delete all the jobs using this plugin please.
I can share my admin details
thanks5 years, 2 months ago #1211383This reply has been marked as private.5 years, 2 months ago #1211414This reply has been marked as private.5 years, 1 month ago #1211467Dear, Please go to admin menu 'Bulk WP' then scroll to 'By Post Types' and select noo_job post type to delete (see attachment) then click 'Bulk Delete'
