NooTheme Premium WordPress Theme › Forums › JobMonster › Broken Layout with elementor
- This topic has 24 replies, 2 voices, and was last updated 6 years ago by
6 years ago #1207480
I have installed jobmonster with the demo sites.
The layout with elementor is broken.
Can you help me?
6 years ago #1207494Dear, please kindly send for me admin account and your site URL via private reply, i will check details to help you.
6 years ago #1207504This reply has been marked as private.6 years ago #1207534Dear, the Jobmonster Elementor demo is installed on your site. That problem because the demo data of Jobmonster use Elementor old version, i don't understand why it not work with elementor latest version.
To fix your problem: I use 'WP Reset' plugin to reset your site then go to admin menu 'Elementor -> Tool -> Version Control' and 'Rollback Version' elementor to version 2.7.5 then import elementor data demo of Jobmonster. Then I update Jobmonster to latest version.
Now, please check your site again.
best reagrds.
6 years ago #1207535This reply has been marked as private.6 years ago #1207552This reply has been marked as private.6 years ago #1207558This reply has been marked as private.6 years ago #1207574This reply has been marked as private.6 years ago #1207592This reply has been marked as private.6 years ago #1207604You can update Elementor to latest version.
6 years ago #1207607Thank you very much!
6 years ago #1207621This reply has been marked as private.6 years ago #1207647Dear, If you want change your site to German, please go to admin menu 'Settings -> General -> Language' and change to 'German'
If you want translate Jobmonster theme, you can use Loco Plugin to do it.
I don't understand your problem please kindly give for me more details. I will check to help you.
6 years ago #1207674This reply has been marked as private.6 years ago #1207675This reply has been marked as private.6 years ago #1207686Dear,I can't login with account your send. please kindly send for me admin account your site via private reply, i will check to help you.
Bets regards.
6 years ago #1207690This reply has been marked as private.6 years ago #1207693This reply has been marked as private.6 years ago #1207694This reply has been marked as private.6 years ago #1207695This reply has been marked as private.6 years ago #1207741This reply has been marked as private.6 years ago #1207743This reply has been marked as private.6 years ago #1207758Dear.
1. What is text can't translate ? Please give for me more details, i will check to help you.
2. To remove image on jobs page, please go to 'Customizer -> Job & Company -> Job List' and remove it in setting 'Insert Custom Content'
6 years ago #1207771This reply has been marked as private.6 years ago #1207798Dear.
1. The Search Job is widget title, please go to Widget to change title.2. the Jobmonster not support custom Job Archive page, it only support change layout of job, please go to 'Customizer -> Job & Company -> Job List' and check it.
