NooTheme Premium WordPress Theme › Forums › JobMonster › Blurry text in advanced search module search fields
- This topic has 13 replies, 2 voices, and was last updated 7 years ago by
7 years, 1 month ago #1069840
Please see attached images.
The text inside the search fields is very blurry on my front page. Can you help me fix this?
ALSO
Is it possible to make the fields in advanced search module on mobile front page the same width as the search fields on jobs page on mobile?
7 years, 1 month ago #1069842The last images showing the search fields width difference on front page and jobs page.
7 years, 1 month ago #1069844Hmm.. here's the missing image!
7 years, 1 month ago #1069845I'll keep on trying - something's bugging here
7 years, 1 month ago #1069846Sorry - the image was to big! My bad - lol 🙂 Here it is!
7 years, 1 month ago #1069848This reply has been marked as private.7 years, 1 month ago #1069955
We added this Custom CSS segment to Customizer > Custom Code > Custom CSS to fix your issue:
h2, .h2{text-shadow:none !important;}
it worked fine.
Please check again, then feedback us.
7 years, 1 month ago #1070011Hi
Thank you, but now there's no shadow on my heading and sub heading.
Before you added the CSS i'd already added custom CSSÂ to Customizer > Custom Code > Custom CSS to add shadow on my headlines.Â
The issue really is that I need H2 shadow on headlines and sub headlines, but not in the search fields text.
Can you help me?
7 years, 1 month ago #1070012Also - I asked if Is it possible to make the fields in advanced search module on front page in mobile view the same width as the search fields on jobs page mobile view?
7 years ago #1070063
We added this Custom CSS segment to help you fix all issues:
@media(max-width:768px){
.noo-job-search-wrapper .job-advanced-search .job-advanced-search-form .form-group .form-control{
max-width:100%;
.noo-job-search-wrapper .job-advanced-search .job-advanced-search-form, .noo-job-map .job-advanced-search .job-advanced-search-form{
padding:0px !important;
.multiselect-container.dropdown-menu li a label.radio {
  text-shadow: none !important;
7 years ago #1070114Perfect!
Thank you very much 🙂
7 years ago #1070126
Posts: 3295This reply has been marked as private.7 years ago #1070133This reply has been marked as private.7 years ago #1070180
