- This topic has 3 replies, 3 voices, and was last updated 6 years, 11 months ago by .
Viewing 4 posts - 1 through 4 (of 4 total)
NooTheme Premium WordPress Theme › Forums › Palazzo › Assign property to agent in admin
how can I assign a property to agent in the admin - no the front end, but the administration.
Since the admin dashboard does not support multilingual upload of properties we want to use the admin of WP but we want to have the properties to be assigned to different agents and have their info displayed in the front end. Advice how to do that.
Regards!
Hi.
To assign the property to another agent in the admin, please go to edit property and assign the property to the author field like this: https://prnt.sc/pize4v
We did that. However there is no information about the agent displayed on the front end of the property.
Do you need some credentials to log in the admin and check if all is OK?
Regards!
To Agent has information to display on the front.
You can try the following steps:
- You add new a Agent -> Select the user corresponding to the newly created agent
- You add the info for Agent. http://prntscr.com/pkvl4f
- Assign Agent has just created into a property
