NooTheme Premium WordPress Theme › Forums › JobMonster › as candidate when I fill the resume form multiselect location field not inserted
- This topic has 13 replies, 2 voices, and was last updated 5 years, 10 months ago by
rajumondal.brainium.
5 years, 10 months ago #1084058
As a candidate when I fill the resume form, multi select location field, other multi select box and also checkbox form field does not inserted into database. But If I do so from wp admin panel then it's all fine.
Can you please tell me why is this happening?
can you check it urgently and reply me as soon as possible.
5 years, 10 months ago #1084098Hi,
Please update the new version to fixed this issue.
(You should backup before updating)
5 years, 10 months ago #1084103Hi Tinhbeng,
Thanks for your reply but in my development server I have updated the theme (noo-jobmonster) but still facing the same issue.
Whenever a Candidate login and Post a Resume , then multi location field, multi select box and checkbox not working , can you please look into it and response as soon as possible. It's an urgent issue.
5 years, 10 months ago #1084112Hi,
You are sure that you are using version 4.0.6.4.
Please send me link your site and wp admin account.
I will help you check.
5 years, 10 months ago #1084154This reply has been marked as private.5 years, 10 months ago #1084188Hi,
Did you check?
5 years, 10 months ago #1084194Hi,
You need to add a purchase code to use the Jobmonster version update function directly on the site.
Currently, each purchase code is limited to 5 different domains.
After you update purchase code, you go to Dashboard -> Update -> update for Jobmonster.
5 years, 10 months ago #1084207Hi,
I have updated the purchase code and also update the theme. Can you please look into it.
It's an urgent basis.
5 years, 10 months ago #1084209Hi,
Also updated the Purchase Code, here I attached the screenshot, please check
5 years, 10 months ago #1084246This reply has been marked as private.5 years, 10 months ago #1084251Hi,
I know it's working from back end but if you login as a candidate and post a Resume form then it's not working. Multi select form fields and checkbox form fields are not working if you fill the form as a candidate login.
Hope, now I clear you everything. Please look into it urgently.
Here below the candidate login details, you may check ( what I sent you before also when send the wp admin details):
username: debarati
password: 123456
5 years, 10 months ago #1084252Hello,
Please, check the attached screenshot, hope I clear you the exact problem.
Please, response as soon as possible.
5 years, 10 months ago #1084264Hi,
It looks like you used Child Theme and overwrote Jobmonster's core files (framework folder).
This will lead to the following problem:
When we have an update in these files, it will not be updated on your site -> because you overwrote it previously with Child Theme.
This is the updated code in the file noo_form_handler.php for the above problem.
5 years, 10 months ago #1084301Yes, Thank you
