NooTheme Premium WordPress Theme › Forums › JobMonster › Apply with Resume should be required
- This topic has 11 replies, 2 voices, and was last updated 7 years, 5 months ago by
7 years, 5 months ago #1072676
I have activated option : "Apply with Resume ( for candidates ) "
I have activated option : "Require attach resume ( <small>An application requires an resume.</small>)"But the attach resume remains mandatory.
7 years, 5 months ago #1072700
Can you provide us some images of your configuration?
In addition, please give us your website's URL & admin account privately via checking Set as private reply checkbox. We will check it directly.
7 years, 5 months ago #1072760This reply has been marked as private.7 years, 5 months ago #1072830
Please uncheck Require attach resume option if you don't want it to mandatory status.
We also checked on our website and it worked fine.
7 years, 5 months ago #1072877I need the user to have registered and choose a CV when submitting a candidature.
But I tried to fill the form and the CV is not required to send the form.7 years, 5 months ago #1072922
We are really sorry but we don't understand your question clearly. Can you tell us what form which you have used now? for instance, post a resume or application form. If possible, please send us an image of it.
7 years, 5 months ago #1072953I have activated option : "Apply with Resume ( for candidates ) "
I have activated option : "Require attach resume ( <small>An application requires an resume.</small>)"In application form, there is a field "attach resume" that should be required in order to send the form. But it is not, and it is still possible to send the form without having attached any CV.
7 years, 5 months ago #1072994
Please provide us with your website's URL & admin account privately because we need to get access to your website and check it directly.
7 years, 5 months ago #1073046This reply has been marked as private.7 years, 5 months ago #1073183
We have got access to your website and checked this issue. Because a candidate account has created a resume yet. That's the reason why when he/she applies for a new job, the Select Resume option doesn't show. Thus, please make sure that your candidate account has a published resume.
7 years, 5 months ago #10733221- A candidate MUST have published a resume before applying to a job.
2- Then, once the candidate has published a resume, he MUST select it while applying to the job.
Those are the settings I need. How may I set this up ?7 years, 5 months ago #1073457
We are so sorry for the late response because we took part in a long national holiday in our country so we cannot help you during that time.
We want to explain below:
Currently, we supported 2 ways in which a candidate can apply for a new job. That's is Resume Attached and Online Resume. Therefore, if he/she doesn't have an online resume, he/she still applies for a job successfully. This action will help job website flexibility.
For your question, there is no way to configure it. we need to change the source code but it will take a lot of time so we will discuss with our developer who can help you with an extra fee.
Please consider it carefully, then feedback us.
