NooTheme Premium WordPress Theme › Forums › JobMonster › Apply via LinkedIn not working
- This topic has 5 replies, 2 voices, and was last updated 5 years, 1 month ago by Anonymous.
5 years, 1 month ago #1071103
I've checked and double checked all my settings here.
When I login as a candidate and try to Apply via Linkedin for a job, I get:
<h3 class="error__message-heading" style="background: none 0% 0% / auto repeat scroll padding-box border-box transparent; border: 0px none currentcolor; color: rgba(0, 0, 0, 0.9); font-size: 24px; font-variant-numeric: normal; font-variant-east-asian: normal; font-weight: 400; line-height: 32px; margin: 0px; outline-style: none; outline-width: 0px; padding: 0px; vertical-align: baseline;">Bummer, something went wrong.</h3>The redirect_uri does not match the registered value
So, I'm not able to complete this step.
There are 2 items on the instructions list that don't make sense:
4. Check on r_emailaddress as your App permission to get the email from your users
I don't know what I need to do to "check on". It's there. I can't do anything with it, though.
6. In the sidebar, choose Javascript then Add your domain to the Valid SDK Domains. It should match with the current domain https://jobs.securityfocusafrica.com
There's no sidebar for me to add a domain to the Valid SDK Domains.
I have old apps in LinkedIn that have Valid SDK Domains as an option but not the new one that I created today.
5 years, 1 month ago #1071123
Please make sure that you add your website to Redirect URLs. Please see this attached image for more details.
You can check, then feedback us.
You must be logged in to view attached files.5 years, 1 month ago #1071148This reply has been marked as private.5 years, 1 month ago #1071154
You are missing "/" at the end of your link. That's the reason why your Linked In doesn't work. Please feed your link exactly: https://jobs.securityfocusafrica.com/
You should check it, then feedback us.
You must be logged in to view attached files.5 years, 1 month ago #1071157Oh no, it was that simple.
The URL needs a / at the end.
I've fixed it and now it works.
I would suggest updating the instructions on the theme so that others don't get trapped like me!
Thank you!
5 years, 1 month ago #1071158
Ok, thanks for your suggestion. We will try to update our instruction about it.
