NooTheme Premium WordPress Theme › Forums › JobMonster › Apply via LinkedIn not working
- This topic has 5 replies, 2 voices, and was last updated 6 years, 12 months ago by
6 years, 12 months ago #1071103
I've checked and double checked all my settings here.
When I login as a candidate and try to Apply via Linkedin for a job, I get:
<h3 class="error__message-heading" style="background: none 0% 0% / auto repeat scroll padding-box border-box transparent; border: 0px none currentcolor; color: rgba(0, 0, 0, 0.9); font-size: 24px; font-variant-numeric: normal; font-variant-east-asian: normal; font-weight: 400; line-height: 32px; margin: 0px; outline-style: none; outline-width: 0px; padding: 0px; vertical-align: baseline;">Bummer, something went wrong.</h3>The redirect_uri does not match the registered value
So, I'm not able to complete this step.
There are 2 items on the instructions list that don't make sense:
4. Check on r_emailaddress as your App permission to get the email from your users
I don't know what I need to do to "check on". It's there. I can't do anything with it, though.
6. In the sidebar, choose Javascript then Add your domain to the Valid SDK Domains. It should match with the current domain https://jobs.securityfocusafrica.com
There's no sidebar for me to add a domain to the Valid SDK Domains.
I have old apps in LinkedIn that have Valid SDK Domains as an option but not the new one that I created today.
6 years, 12 months ago #1071123
Please make sure that you add your website to Redirect URLs. Please see this attached image for more details.
You can check, then feedback us.
6 years, 12 months ago #1071148This reply has been marked as private.6 years, 12 months ago #1071154
You are missing "/" at the end of your link. That's the reason why your Linked In doesn't work. Please feed your link exactly: https://jobs.securityfocusafrica.com/
You should check it, then feedback us.
6 years, 12 months ago #1071157Oh no, it was that simple.
The URL needs a / at the end.
I've fixed it and now it works.
I would suggest updating the instructions on the theme so that others don't get trapped like me!
Thank you!
6 years, 12 months ago #1071158
Ok, thanks for your suggestion. We will try to update our instruction about it.
