NooTheme Premium WordPress Theme › Forums › JobMonster › Advanced Search Problems
- This topic has 10 replies, 2 voices, and was last updated 6 years, 4 months ago by
6 years, 5 months ago #1079615
Hey!
I used a advanced search Widget on the company page. Therefore I created a new field, (company-type), so that I can filter the companies.
The problem is, that not all companies are shown after filtering, although they have a company type.
Example: I have 4 Hospitals on my page. When I want to show hospitals only, there are only 2 hospitals shown. Same with other filters.
I already cleared the cache, but it does not work.
Do you have a solution for it?
6 years, 5 months ago #1079616This reply has been marked as private.6 years, 5 months ago #1079658Hi,
Currently location only filters by ID and does not distinguish parent Location and sub location.
If a hospital belongs to "Kiel", you need to select the location "Deutschland and Kiel" => Filter will work.
6 years, 5 months ago #1079700But i created custom fileds on the company-profile. I can't select a parent- or subcategory.
The Filter comes up in the advanced search widget, but the fileds do not work correctly:
- I have 6 "krankenhaus" (Hospitals) listed als companies.
- when i want to show "Krankenhaus", there are only shown two of them. Of course, the other companies have chosen this custom field as well.
- when i want to change to display all companies with this filter, there are only shown 3 of all companies.
I think the customfield and the filter do not work correctly - why? Any solution?
6 years, 5 months ago #1079703more screenhsots to show the problem....
6 years, 5 months ago #1079721Oka, I got the problem.
When I use two widgets for advanced company search, it works.But: why is it not possible to choose "show all locations" in the search widget?
I HAVE TO choose a location, and of course, he will not find a hospital in Berlin, when there is no hospital. But I want to display EVERY HOSPITAL on on EVERY Location, without chosing a location.If a candidate wants to search for hospitals and it's not important to him, where they are, he can't do it.
It is a bug or does this function not exist?
6 years, 5 months ago #1079746Hi,
I updated some code lines to the "wp-content/themes/noo-jobmonster/framework/member/company-default-fields.php". (This custom content will be lost when you update the theme. You should save the attached file below, in case you update the theme)
6 years, 5 months ago #1079795Oh Thanks!
The custom Search filed is working now, thanks a lot!
But the location field has only 3 entries, although I have much more locations. Now that field doesn't work correctly.And: If I chose a location out of the 3 possibilities (e.g. Bremerhaven) and a Hospital out my customfield below, he's not finding any matches, although there is 1 Hospital in Bremerhaven.
So the 2 fields do not work togehter correctly, only the custom field is working correctly. Sorry :/
Kind regards!
6 years, 5 months ago #1080005Hi,
You should select the type "Multi Select" for this field.
6 years, 4 months ago #1080638No, it does not work.
When I choose "Hospital" (=Krankenhaus), then only 2 are shown. But I have MORE than 2 Hospitals on my jobboard. The Search does not work! And a "Multi-Select" is not, what I want. Because I want to categorize the Companies with only 1 option and not 2 or more options.
So, what should we do now?
6 years, 4 months ago #1080747Hi,
I'm not sure about this issue.
