NooTheme Premium WordPress Theme › Forums › Jobica › Add new Job Type Parent and Sub Category frontend display Issue
- This topic has 8 replies, 2 voices, and was last updated 6 years, 2 months ago by
6 years, 6 months ago #1079289
While creating new job type categories, on the frontend it does not show job categories under parent category.
Please see the attached screenshots for what I mean.
For example, Academic Posts is the Parent Job Type and under this I have the following sub-categories. But when I check from the frontend, it does not show sub-categories under the parent category but shows subcategories as separate parent categories.
<colgroup><col style="mso-width-source: userset; mso-width-alt: 14665; width: 301pt;" width="401" /> </colgroup>
<tbody>Professors / Chairs Readers / Senior Research Fellows Principal / Senior Lecturers / Associate Professors Lecturers / Assistant Professors etc. </tbody>
MY LOGIN DETAILS are in the next private message
Same for all other job type parent and sub-categories.
Please help resolve this issue. Thanks
Mir
6 years, 6 months ago #1079292This reply has been marked as private.6 years, 6 months ago #1079333Hi,
we are unable to update this right now.
We will update it to one of the upcoming releases.
6 years, 5 months ago #1080514hi there,
This issue is still unresolved. Please see the query in the thread above as well as the images attached.
Kind regards,
mir
6 years, 5 months ago #1080606Hi,
With the current release we focus on the Job Filter widget and Job map functionality.
The above issue is not yet included in this release. We will update it in the next release (in November).
6 years, 2 months ago #1083163Hi there,
has this issue been resolved. Please read the thread fully before replying.
You told me it will be taken up in November. But, the issue is still pending.
Please help resolve it soon.
The login and password details of my website are the same as above.
mir
6 years, 2 months ago #1083282Hi,
I have some updates for the Job Type field.
6 years, 2 months ago #1083392Thanks Tinh Beng,
It works fine.
But similar problem with Location field. Please check the image.
I hope you can also resolve the issue here
Kind regards,
mir
6 years, 2 months ago #1083424As you can see, the Location field is already hierarchical, if you want to use multiple selections: you go to Jobmonster -> Custom Field -> Job tab -> set "Multiple Location" instead of Single
