NooTheme Premium WordPress Theme › Forums › Jobica › A few more minor glitches.
- This topic has 11 replies, 2 voices, and was last updated 6 years, 2 months ago by
inmagine.
6 years, 2 months ago #1204449
Thank you for everything so far, you've been extremely helpful.
Here are a few more things I've found that I hope you can resolve.
(see attached image for full details)
1. (A) In the Customizer for Blog-Single Page, I've enabled the Social Sharing and it shows in the Customizer.
However in (B) the actual page, it's missing.2. I changed the header image for blog posts (see image in 1) but how to change it when I search under the tags / in the archive?
3. The header navigation is fine on the home page, but in the Manager it moves to the center, it should be justified right the same as the home page.
6 years, 2 months ago #1204451Sorry I forgot to add.
2. How can I disable the 'Author' from this page?
6 years, 2 months ago #1204462Dear, i think that problem because cache on your browser, because i check your site and see all settings is working like attachment, please check your site again.
6 years, 2 months ago #1204467This reply has been marked as private.6 years, 2 months ago #12045162. Sorry, current version not support change image heading for post tag and post category, we're will change post tag page and post category page to use Blog heading image in next update version
3. Please add custom CSS on your site
#content-dashboard-tc .navbar-collapse{ text-align: right; }6 years, 2 months ago #12045562. That would be great - thanks! You might want to consider the ability to add either a custom Elementor header or footer... at the moment, you can only add both or none!
3, Worked fine, thanks!
6 years, 2 months ago #1204621Dear,
2. I don't understand your questions because if you use Elementor Pro plugin. you can custom header and footer with Elementor Pro plugin.Best regards.
6 years, 2 months ago #1204781Dear, 2. I don't understand your questions because if you use Elementor Pro plugin. you can custom header and footer with Elementor Pro plugin. Best regards.
Yes, I know you can design custom header and footer. The problem with your theme is that if I create only a custom footer, the standard header vanishes. Same if I create a custom header, the standard footer will not show. You have to create BOTH custom header and footer. Where I would ONLY want to create a custom footer with the standard header that's already there.
The same goes if I want to create a custom Post Type, both the standard header and footer disappear.
I wish you would fix it so we can create singular custom sections without the other parts vanishing.
6 years, 2 months ago #1204807This reply has been marked as private.6 years, 2 months ago #1204841This reply has been marked as private.6 years, 2 months ago #1204859Dear, i have check Elementor Pro plugin, i see that problem because when use Elementor Pro not support use Footer or Heder builder on page, it forces both, mean, on your site, if you use custom footer builder, you also have to build header. You can contact with elementor pro to ask that problem.
6 years, 2 months ago #1204863OK, thanks for the answer, I'll ask in the support group for Elementor.
