NooTheme Premium WordPress Theme › Forums › JobMonster › 3 bugs
- This topic has 8 replies, 2 voices, and was last updated 7 years ago by
alex91.
7 years, 1 month ago #1068553
contacted you already 2 times via mail but I didn't get any answer. See the enclosed presentation for the bugs
7 years, 1 month ago #1068554This reply has been marked as private.7 years, 1 month ago #1068617Hi.
1. Front-end PM plugins using to contact the employer with the candidate, the application can't display in Front-end PM. It is completely different.
2. When you use the reporting the expired job, it will go to activate or pending. It depends on your Job Approval setting.
- Refresh job: use to refresh job posting date time, to make the activate job go to the first of the job listing.
- Reposting: use to repost the expired job. https://prnt.sc/mkvxs9
3. With the expired date, it will get the expired date from display time as the package when the job public.
We have checked your site, try to post a new job and it still works fine. https://prnt.sc/mkw0oe
7 years, 1 month ago #10686291: what do you say? in back-end=>jobmonster=>settings=>messages=>second point: it clearly says:
application message: Start conversation when a candidate has applied for a job.
so why do you tell me there is no integration with WP FRONT END PM and that there is no such option???
3: have you even seen my screenshots? as shown, there is a bug with the packages! some jobs have a expiring date, some not. how come if they both have the same package???
7 years, 1 month ago #1068631Hi again.
Can you give us a link about the ticket? We don't remember about this.
When you received the application, you will see the message icon, where you can send a direct message to the candidate. We use the Front-end PM plugin to sending and manage the message.
3. With the [email protected] account? Do you have that account info? We have check our account on your site and it still works fine.
7 years, 1 month ago #1068632This reply has been marked as private.7 years ago #1068910what about bug number 3??
3) yes. [email protected] does not have an expiration date but [email protected] has. they both have the same package as you can see. But do not edit anything with their account or job, these are real users
7 years ago #1069376Hi again.
With the job submit without expired date info, we have found some way to help you check it with the "[email protected]" user.
We need the FTP account to debug the source code.
Or you can use the function var_dump(jm_get_job_posting_info(287)); to debug.// 287 is the user_id.
Please check it and give us that info again.
7 years ago #1069450this code works also for new/future users?? what was the problem?
