This topic contains 7 replies, has 2 voices, and was last updated by Tracy Bui 2 months, 2 weeks ago.
3 months ago #1063804
After buying and installing your plugin, we proceeded to add classes to the schedule.
The problem is the following: all but one class are stuck in a perpetual state between being hovevered over and not. Upon hovering on them they get further expanded (see screenshots bellow).Additional data:
WordPress 4.9.8 running Asana theme.Attachments:
You must be logged in to view attached files.3 months ago #1063841Hi,
Please give us your website's URL& admin account and FTP account privately via checking Set as private reply checkbox. We need to check this issue directly.
3 months ago #1063874This reply has been marked as private.3 months ago #1063926Hi again,
We understood your question. It seems that you want to classes which is expand when displaying in schedule, don't you?
In this case, Timetable supports to display as you can see this image https://prnt.sc/lkkdja When a visitor wants to see each class, he/she need to hover to view full information or click to this class to see - a pop-up will be displayed and he/she can go to class detail.
Why we made it because it is convenience when your schedule has many classes, they cannot display with full information because there is not much space to show.
If you don't have many classes, we can help you to show class with expanding view but the time doesn't correspond correctly.
Please check again, then feedback if you get another point.
2 months, 3 weeks ago #1064365It would be preferable if they can expend, though that is not necessary.
What we would really appreciate is the classes not showing half way, as can be seen on the screenshots above - which is clearly a bug 🙂2 months, 2 weeks ago #1064417Hi again,
This isn't an issue. As we told above, because you have configured the time too small(30minutes for each class) so the class will be displayed small.
In this case, you should increase the class time to get rid of this issue.
Please check again, then feedback us.
2 months, 2 weeks ago #1064454Dear Tracy,
I've indeed confirmed that your popup only works as it should when the class is set to last EXACTLY one hour.
What you are proposing is basically a workaround in which all of my client's classes should not begin or end on the :30 (even though they might last, say an hour and 30 minutes - no classes were set to last only 30 minutes).
However, you've helped us make sense of the problem and we've sorted it out by forcing a greater table row height, allowing for the popup to show completely. For us, this solves the problem.However, I would just like to point out that this IS a bug and definitely not the proper way this should work, so I'd suggest that you look into the way you implement your popups as part of some future release.
Thank you for your time and suggestions.
2 months, 2 weeks ago #1064501Hi again,
Thanks so much for your comment.
We understood your question so we will discuss with our developer about this then improve our plugin in the future.
