NooTheme Premium WordPress Theme › Forums › Organici › Visual Composer – not working
- This topic has 5 replies, 2 voices, and was last updated 4 years ago by
Junnie.
4 years ago #1022269
As visual composer was not working with your team and it did not offer the possibility to use templates nor get any service from the visual composer developers I decided to purchase visual composer but this did not change the problem which I was experiencing in that it was simply not working.
It did not work in different browsers, it did not work having deleted all my caches, it did not work when I switched off all my plugins etc etc.
Am aware that you customized some settings in the vc you included in Organici but it did not work and I have now installed a newly bought vc. Can you please tell me what to do ? Thanks
4 years ago #1022377Hi,
Wish you a nice day.
Sorry for my late responsiveTomorrow, I will check this issue for you. You do not need to buy visual composer plugin
Junnie4 years ago #1022380As I said, I felt I needed to buy it as the version which came with Organici did not work to my satisfaction.
Also the service and the templates when bought sounded attractive.
Had contact with their service desk and asked them how come it didn't work (mainly the Visual button in the editor and the Front End Editor). Tested a lot and here is my summary.
Think the issue is clearly with Organici....
This is what I tested and concluded:
quote---
Hi again,Conclusion from the below: Problem with Organici and VC in generalProblem of VC with AUtoptimize and W3C Total caching plugins, perhaps you can tell me what I have to change in the settings of these programs for VC to work?What I did (as you suggested):In Twenty-Seventeen:1) Did all you said and this time (did you just upgrade to 5.01 ?) Front end editor worked with all plugins switched off and theme twenty seventeen.2) Next activated within same theme all my plugins again and it did not work again3) Next I deactivated my 4 cache plugins and front end editor worked again4) Activated Autoptimize and Front End Editor did NOT load so deactivated it again5) De-Activated Autoptimize and Front End Editor loaded again6) Activated Better WordPress Minify again and Front End Editor worked!7) Activated W3C Total Cache again and Front End Editor still worked!8) Activated WP CDN Rewrite again and Front End Editor stopped working again9) De-activated WP CDN Rewrite and Front End Editor worked againConclusion with theme Twenty Seventeen there is impact from both "Autoptimize" and "WP CDN Rewrite"With both "Autoptimize" and "WP CDN Rewrite" off I switched back to Organici:Although I see the page loaded in the background but the turning logo does not finish and Front End Editor does not start.Next I while still in Organici theme I switched all plugins off except VC:This time I do not see the page loaded in the background the turning logo does not finish and Front End Editor does not start.OVERALL CONCLUSION:- with Theme twenty-seven Front End Editor does not work while the 2 cache plugins Autoptimize and "WP CDN Rewrite" are activated but works fine with when these are switched off.- with Theme Organici (From Nootheme.com) Front End Editor does not work at all (without any plugins active except VC).For a prtscrn of the loading error with VC logo active but not loading I can not get anything from Console. sorry.MartinUnquote--
Please help!
thanks
Martin
4 years ago #1022580Hi,
Please go to Cloudflare and turn off option Rocket Loader
http://prntscr.com/e3u959 Your current web page does not load jquery library. js so is error
http://prntscr.com/e3u9o5Best regards,
Junnie
4 years ago #1022655The visual editor still does not work! I do not see the icons to change / format my text etc.... Please advise what is going on. Thanks!
You make life very difficult for me! It is all not working, I'm starting to wonder if I made the right choice? This is really ridiculous.
4 years ago #1022717Hi,
This is not the fault of our products
Step 1: Deactivate W3 Total Cache plugin
Step 2: Active Organici theme
http://prnt.sc/e4a6niStep 3: Active child theme go to public_html/wp-content/themes/noo-organici-child/functions.php and comment code the same as image below
When I comment 2 lines in functions.php I can use front end editor
http://prntscr.com/e4adp3
Best regards,Junnie
