NooTheme Premium WordPress Theme › Forums › iVent › Translation problems
- This topic has 14 replies, 3 voices, and was last updated 4 years, 10 months ago by Anonymous.
5 years ago #1072371
Hi, i try to translate some labels on the "simple search" and on the "find event" tribe research (see attach)
some words i cannot able to change: "Venues" and "Cerca eventi" (see attach)
can you help me?
thanks in advande!
You must be logged in to view attached files.4 years, 12 months ago #1073091Hi.
Thank you for contacting us and sorry for the late response.
With the find events string, you can find the language "Find %s" at the language file of "The Event Calendar" plugin.
4 years, 12 months ago #1073111sorry but i do not understand: maybe i do not exlain well my problem is to translate in italian the word "venues" in the search strip
where i can find the string ?
thanks in advance
You must be logged in to view attached files.4 years, 11 months ago #1073290Hi again.
Can you give us that link? We need to know the venues text position.
4 years, 11 months ago #1073672This reply has been marked as private.4 years, 11 months ago #1073809
Posts: 3295This reply has been marked as private.4 years, 11 months ago #1073840This reply has been marked as private.4 years, 11 months ago #1074126This reply has been marked as private.4 years, 11 months ago #1074457
Posts: 3295This reply has been marked as private.4 years, 11 months ago #1074707This reply has been marked as private.4 years, 10 months ago #1074998Hi again.
It still has limited access with that account. We need to install the Loco translate plugin to help you find and translate the string "venues"
Please check it again, or you also can use the Loco Translate plugin to do that.
4 years, 10 months ago #1075410This reply has been marked as private.4 years, 10 months ago #1075462
Please try to go to {root}\ivent\wp-content\themes\noo-ivent\functions.php line 135 then change this text directly. Also, see the attached image for more details.
You must be logged in to view attached files.4 years, 10 months ago #1075619thanks! finally i resolve!
ag
4 years, 10 months ago #1075664
If you have another question, don't hesitate to create a new topic on our forum. We will try to help you as soon as possible.
