NooTheme Premium WordPress Theme › Forums › JobMonster › Translation Plugin Loco – Not translating some words
This topic contains 9 replies, has 2 voices, and was last updated by Tracy Bui 1 year, 3 months ago.
1 year, 3 months ago #1058826
Hi!
I have used the Loco Plugin in order to translate my website, just like you recommended. However there are still some words that are not being translated.
On the main page the tabs
- "Featured Jobs"
- "Recent Jobs"
On the Manage Followers Section, on the profile section the words
- “Show X Entries”
- “Showing X to X of X Entries”
- “ No Data available”
- The “Search” field
- The buttons “Previous” and “Next”
Could you please help me?
These last words are the reason why I havent launched my website yet =/
Thank you!
You must be logged in to view attached files.1 year, 3 months ago #1058874Hi,
Please give us your website's URL and admin account privately via checking Set as private reply checkbox.
We will check these words on your website directly.
1 year, 3 months ago #1058904This reply has been marked as private.1 year, 3 months ago #1058936Hi,
We checked on our website carefully. Currently, we use dataTables library to make this page so you cannot translate these texts by Loco Translate plugin.
We will guide you to change these text by edit the source code: Please go to{root}/wp-content/themes/noo-jobmonster/assets/vendor/DataTables/datatables.min.js
- These text "Showing 0 to 0 of 0 entries" line 11431 as image 1
- Previous and Next line 11353 and 11374 as image 2
- "No data available in table" line 1752 as image 3
- "Search" line 11672 as image 4
You must be logged in to view attached files.1 year, 3 months ago #1058939image
You must be logged in to view attached files.1 year, 3 months ago #1059065Hi,
Thank you for the reply.
Can you tell which program are you using to open the .js file?
1 year, 3 months ago #1059128I have tried to change the text you said, but I dont see any changes on the website.
I am editing the file with the Notepad++
You must be logged in to view attached files.1 year, 3 months ago #1059195Hi again,
We have use sublime text to open source code https://www.sublimetext.com/3
You can download to use.
Please try to change again your source code. If you cannot change it, please give us your FTP account to access your code. We will check, then feedback you.
1 year, 3 months ago #1059261It Worked!
Thank you for your help!
1 year, 3 months ago #1059325This reply has been marked as private. -
