This topic contains 9 replies, has 2 voices, and was last updated by Tracy Bui 3 months ago.
3 months, 2 weeks ago #1063532
Is there a simple custom code I could add to the ntt-schedule.php part with the popup to add a Read More link going to the same url as the event/class title link in the popup?
I am currently using the register link as a read more button link instead but this involves having manual time adding the link to the event/class when it could be done automatically with custom code.
In light of this, for the popup modal, I think it could be improved with these features:
1. Option in settings for the title link of class/event to open in new tab (target="_blank") instead of the same window.
2. Option to add a "Read More" button that opens link to class/event url in new tab (as I am currently attempting by editing the ntt-schedule.php)
3 months, 1 week ago #1063609Hi again,
It seems that this is a customization question.
We are so sorry but we haven't supported these features yet.
1- We will discuss with our developer about this question, if possible we will add to next version of Timetable plugin.
2- For Read More button, can you provide us with an image to describe the position which you want to add it?
We will check, then feedback you soon.
3 months ago #1063953Thanks for your reply.
For 1. Open link in new tab, I have resolved with JQuery for now. To me, it makes sense to open in new tab otherwise they have to click back to view the schedule.
For 2. Read more button in the modal popup, I am using the Register button instead right now. But a Read more button could be a button or link at the end of the excerpt.
Aduo
3 months ago #1063985Hi again,
We also access your website to find "register button" which you are focusing but unsuccessfully. Also, see this image https://prnt.sc/lkyu7s
You can check, then describe your question as clearly as possible if you still need to help.
Thanks so much.
3 months ago #1064009No, I changed register button to say "Read More" ... it's not on all the classes yet, but it's on *Evening Vinyasa class.
I customised the register button so that I can have a "Read more" link. This is just feedback for you that a read more link after the excerpt might be good idea to have in a future version, because I needed it so maybe other people may need it too.
3 months ago #1064040Hi again,
We are really sorry but we don't understand your question clearly. We also access your website but we don't see Read More link in Evening Vinyasa class as you described.
Can you please explain your question via images? We will check and add to Timetable plugin in the future if possible.
3 months ago #1064043Your plugin does not have a "...read more" link at the end of the popup excerpt. I've changed "register" button to "read more" instead.
https://www.dropbox.com/s/h5kh7dzt1czflvr/read-more.png?dl=0
Feature request for other users is that you have a "...read more" link at the end of excerpt. Like when you see an excerpt of a blog post, it has a "...read more" link.
3 months ago #1064045Hi again,
We understood your question so we can explain below:
First, when you click on the class on schedule, a pop-up is shown that you can see the class summary. Then if you want to see all the information of a class, you can click to class title. It will be redirected to class detail. That's the reason why we don't add Read More button as your desired.
In addition, we also check another topic related to the database but we need much time to check.
Please wait for us, we will try to feedback you soon.
3 months ago #1064046Yes, I understand. I don't agree that that is enough. Just like in a blog post excerpt has both because some people don't know that you can click on the title. That's just my feedback.
3 months ago #1064049Hi again,
We will consider your feature if there are many customizers have the same questions. We will discuss with our developer to make it to the Timetable plugin.
We are so sorry for this inconvenience and thanks for your understanding.
