This topic contains 14 replies, has 3 voices, and was last updated by Tracy Bui 3 months, 1 week ago.
3 months, 2 weeks ago #1063255
Hi Noo team,
I has saw this part (in the picture in attachment file) in your demo Homepage6, but when I active Homepage6 template in my dashboard this part was not appear
How can I fix this problem?
You must be logged in to view attached files.3 months, 2 weeks ago #1063262Hi,
You should configure as this image: https://prnt.sc/leioa0
We also helped you to configure on your website: http://thehomeshop.vn/home-page-6/
3 months, 2 weeks ago #1063267oh I see,
Thank you so much !
3 months, 2 weeks ago #1063294Hi again,
I dont know why the sceen show like this at the first time access to home page (in the picture in attachment)
Another problem is the Frontend Editor of WPBakery Page Builder is not work correctly
Please check these problems for me
Thank you !
You must be logged in to view attached files.3 months, 2 weeks ago #1063305Hi again,
We helped you fix this issue on Homepage, it works fine. Please see this image https://prnt.sc/lewsd7
For Visual Composer shortcode, it works normally.
3 months, 2 weeks ago #1063340Hi,
Have a good day!
I has checked my site
The problem about screen apperance has been fixed, and it work correctly
But about the Frontend Edition function still not work. When I click on this button, it show nothing
Please check it for me
You must be logged in to view attached files.3 months, 2 weeks ago #1063372Hi again,
Please give us your FTP account to access your source code, we will check your issue.
3 months, 2 weeks ago #1063420This reply has been marked as private.3 months, 2 weeks ago #1063426Hi,
I checked the above issue. The button "Frontend Editor" still normal works.
You can remove the cache and try again.
3 months, 2 weeks ago #1063512Hi again,
thanks for your support,
I dont know how it work correctly again, although I removed cache and cookies before checked again so many time
By the way, can you show me how to fix this problem? The appearance of this line is not full for our language
You must be logged in to view attached files.3 months, 1 week ago #1063587Hi again,
You can use this Custom CSS segment to Customizer > Additional CSS to fix:
@media(max-width:768px){
.noo-product-header h3{font-size:32px !important;}
3 months, 1 week ago #1063627Hi again,
I has tried your code, but it didn't work
You must be logged in to view attached files.3 months, 1 week ago #1063677Hi again,
We helped you to fix this issue by adding this Custom CSS segment:
.noo-product-header h3{font-size:23px !important;}
it works fine. Please check again, then feedback us.
3 months, 1 week ago #1063703Hi again,
I has tried your way but it still not work
I think you has not understand me yet
You can see these images in attachment file to know what I mean
You must be logged in to view attached files.3 months, 1 week ago #1063741Hi again,
We understood your question. In this case, we helped you to add margin-top:10px to fix this issue.
You can check again your site.
