NooTheme Premium WordPress Theme › Forums › Timetable › Problems with design – Class Item Style
- This topic has 17 replies, 4 voices, and was last updated 5 years, 1 month ago by tinhbeng.
5 years, 3 months ago #1067056
i choose Category Color in the Class Item Style but it show me the Background color by category style...
i dont knoe what to do...?
dorin
5 years, 3 months ago #1067108
Thanks for your contacting us.
Please give us the images again because it got the issue so we cannot understand your question clearly.
5 years, 3 months ago #1067112this is the url
5 years, 3 months ago #1067193hello...
is any body there?
5 years, 3 months ago #1067250
We are so sorry but we cannot see your image so you should upload it to https://imgur.com/ so we can help you better.
In addition, please give us your admin account because we want to check your configuration.
5 years, 3 months ago #1067364This reply has been marked as private.5 years, 3 months ago #1067402
1- Please see this image: https://prnt.sc/m9xfka
We have seen that you uploaded an image on your topic but it got the issue and we cannot see it. That's the reason why we asked you again.
2- We want you to provide your admin account of your website because we want to check some configurations on your site and make sure that you have configured exactly.
3- As you told above, you lose some demo pages, please tell us the exact pages which you lose. We will help you to configure again. In addition, you can import our sample data again to get them back.
Please check our answer then feedback us again.
5 years, 3 months ago #1067418This reply has been marked as private.5 years, 3 months ago #1067619hello...
is any body there?
5 years, 3 months ago #1067675Hi again.
We have updated the plugin to fix the issue with class tyle color. Can you install that version 2.0.5.1 to your site and check it again?
If yes, please give us your site admin account.
5 years, 3 months ago #1067700This reply has been marked as private.5 years, 2 months ago #1067822Hi,
Please remove the plugin Timetable and go to this link download the last new version and install it.
https://codecanyon.net/item/noo-timetable-responsive-wordpress-timetable-plugin/17511898
Currently, I can't login your site.
5 years, 1 month ago #1070289Hello again
It is not clear to me why but the show of the board lessons disappears on mobile ..? The display on the computer on a large screen appears but the mobile disappears ...?
5 years, 1 month ago #1070350
Posts: 3295Hi again, dorin
We also got access to your website to check this issue but unsuccessfully.
Please help us to check your website again and give us your FTP account privately via checking Set as private reply checkbox. We will check your issue as soon as possible.
5 years, 1 month ago #1070747Hi againPlease go back and see if you have successfully entered the siteI removed an extension that restricts the ability to sign in from external countriesThe mobile view of the event schedule has disappeared on the mobile display ... it worked in the past and I have not changed anything ...I do not understand what the problem might be and why there is no mobile display ??? In the past there was ...5 years, 1 month ago #1070759This reply has been marked as private.5 years, 1 month ago #1071016This reply has been marked as private.5 years, 1 month ago #1071030Hi,
Currently, you use the version 2.0.5.1, please update the last new version (2.0.5.4).
This problem fixed on the last new version.
