NooTheme Premium WordPress Theme › Forums › Pearle › Portfolio
- This topic has 32 replies, 3 voices, and was last updated 4 years, 8 months ago by
Junnie.
4 years, 11 months ago #34568
Hi, I need to hide"ALL" category from porfolio beacuse it is the problem when you have to many categories and projects. Let me know how to hide it.
4 years, 11 months ago #34629Hi,
I am sorry for the late response. We are having a Lunar New Year Holiday (it lasts from 8/2 to 14/2/2016); therefore, I can not assure that we will reply you promptly. We hope you can sympathize with this.Please go to admin panel/customizer/custom code/custom CSS and add this code
.masonry-filters-services .services-filters li:first-child { display: none; }
ThuyNT4 years, 11 months ago #34653It doesn't work. I pud the code and it doesn't change anything.
4 years, 11 months ago #34709Hi Bonivest,
Please send me link of your site and your admin account via private message. I will check help you soon
http://prntscr.com/9yrcrd
ThuyNT4 years, 11 months ago #34733This reply has been marked as private.4 years, 11 months ago #34774Hi Bonivest,
Wish you a nice day.
Please send me username and password admin via private message. I will check help you soon
http://prntscr.com/a3tsz4
I am sorry I can go to your site with link http://torro.bonivest.pl/
maybe your server has blocked our IP or our country, Vietnam. Please check that. Our IP is 113.190.233.73
ThuyNT4 years, 11 months ago #35254Hi,
I don't see in WordPress backoffice an option to hide thes category...
Just let me know where is it in the root? what file and code ?? I will hide it by mysefl...but don't know how to find it...
4 years, 11 months ago #35367?????
4 years, 11 months ago #35371Hello,
We will try help this issue. You can find it with path:
plugins/noo-carle-library/admin/vc_extension/shortcodes/noo-project-grid.php.
Thanks!4 years, 11 months ago #35399ok thanks, but still have the problem how to hide ALL category portfolio products ??? It shows all products from all categories and if I have lots of products it takes too much space on the website...
4 years, 11 months ago #35402Hello,
We will add function pagination for shortcode in new version, current you can using shortcode "Noo Projects Slider".
Thanks!4 years, 11 months ago #36218Hey,
I'm not interested in Projects Slider. I want to disable ALL projects view at my portfolio grid?
Do you understand? If I have 120 projects, I want to filter that. Instead to that I have 120 projects on my main site. OK??? All I want from you to give an answear how to disable that or just a code to paste in the root...4 years, 11 months ago #36357it is important, can you resolve the issue????
4 years, 10 months ago #36476Hi Bonivest,
I sorry for last weekend is a holiday, so I do not support you get.We will create new shortcode. This shortcode, you can disable Tab All of Portfolio. Please wait.
For Noo Services Gird shortcode. At the moment, this shortcode can not disbale Tab All of Portfolio.
ThuyNT4 years, 10 months ago #36550I'm not using services grid , but projects grid.
When will it be done?
4 years, 10 months ago #36653Hi,
We will release on Saturday. If you want to quick fix. Please send me FTP account and admin account via private message. Our web developer will fix help you
Please wait
ThuyNT4 years, 10 months ago #36788This reply has been marked as private.4 years, 10 months ago #36794I’m sorry but I can’t access your site and your FTP with the username and password you gave me.
Please go to plugin/noo-carle-library/admin/vc_extension/map and replace by file attached ( upzip before replace)
Please go to plugin/noo-carle-library/admin/vc_extension/shortcodes and replace by file attached. ( upzip before replace)Best regards,
ThuyNT4 years, 10 months ago #36815I have uploaded the files and to be honnest now it is even worse!
Why I can't hide the ALL catogory??
For now after changes the projects are duplicating!?!
Doesw the the developr didn't realize that this is a big problem??
120 projects and all of it visible on the main page, the filters are useless, this is bullshit!!!
4 years, 10 months ago #36816If I set the limit projects from other categories are not visible. Can you tell what changes are made now? I writing all the time about the visibility of ALL category and all projects and filters because of that are useless. All projects takes to much space on the homepage, do you even understand that, because I see you don't know what I am writing about????
4 years, 10 months ago #36865Hi Bonivest,
Please install teamviewer and give me ID and password. I will edit help you.
I am sorry for my late responsive because our timezone is different from yours. when you were creating a topic, our daily time working ended.I need login to your admin and your hosting(FTP/cpanel). But I can't
ThuyNT4 years, 10 months ago #36867Noo-project-gird.php
Please go to plugin/noo-carle-library/admin/vc_extension/shortcodes and replace by file attached. ( upzip before replace) ( New file)
Portfolio.js
Please go to noo-carle/assets/js and replace by file attached. ( upzip before replace)
When we release new version. Please save 2 file Portfolio.js and Noo-project-gird.php.After update theme, Please replace file again
We suggest that you should back up your data.Then you will update the latest version. After updating, you will copy sections that you made some changes.
ThuyNT4 years, 10 months ago #36937Thank you, now it works propertly.
4 years, 10 months ago #36984You're welcome.
Nice to support youBest regards,
ThuyNT4 years, 10 months ago #38552Hey, how to switch order of portfolio categories?
