NooTheme Premium WordPress Theme › Forums › Other Products › Noo Menu › Old Menu won't go away
- This topic has 12 replies, 3 voices, and was last updated 3 years, 11 months ago by
Kan Nguyen.
3 years, 11 months ago #1022995
When I installed the nootheme menu it won't overwrite or let me edit over the default theme menu I had. What to do ? Please advise
corporate.siretskiy.com
3 years, 11 months ago #1022997Also I do not see any preset styles etc...
3 years, 11 months ago #1023028Hi,
Please provide me link of your site and your admin account via private message. I will check for you soon.
http://prnt.sc/ctnxjd
Regards,
Junnie3 years, 11 months ago #1023097This reply has been marked as private.3 years, 11 months ago #1023120This reply has been marked as private.3 years, 11 months ago #1023140Hi,
Please check your site again. I edited for you
Junnie
3 years, 11 months ago #1023197This reply has been marked as private.3 years, 11 months ago #1023213This reply has been marked as private.3 years, 11 months ago #1023255Hi,
The problem is because you install then Network Activate the plugin so the preset style can't be initialized. I fix it by:
1. Network Deactivate
2. Activate on one site, corporate.siretskiy.comThen you can see the Preset style on the Menu Control Panel: http://prntscr.com/e6wz76
Kan3 years, 11 months ago #1023283This reply has been marked as private.3 years, 11 months ago #1023313Hi,
I can use the pre-set style without any problem. I've activated the Crystalline Black style on your site.
http://prntscr.com/e7zy4w
http://prntscr.com/e7zxvkBtw, when I first checked your site today, I saw that the pre-set styles are missing again. Did you do any change?
Kan3 years, 11 months ago #1023517Please fix them again one more time, didn't do any changes just wanted to see if we can make it double effect, but now this white line showing. Thanks a lot !
3 years, 11 months ago #1023536I added this simple CSS code to your menu to fix this issue:
.noo-megamenu .dropdown-menu .mega-nav, .noo-megamenu .mega-nav { display: block !important; position: static !important; border: none !important; background: initial !important; }
Please make sure that you have this CSS the next time there's change.
Kan -
