NooTheme Premium WordPress Theme › Forums › Other Products › Noo Menu › NooMenu no writing
- This topic has 11 replies, 3 voices, and was last updated 4 years ago by
Kan Nguyen.
4 years ago #1023310
My written English is not very good.
However, I will try to be clear.
I use the Beaver Builder theme (which I bought.)
I installed and activated the NooMenu plugin.
But when I look at my site, writing the menu is not visible.
Instead, there is a "Menu" text and I have to click on it to make it appear.
While I would like to see the menu horyzontally.
What's wrong?
The site: http://www.centre-socio-sarrebourg.fr/Thank you for your help.
4 years ago #1023344Hi,
Please provide me link of your site and your admin account and FTP account via private message. I will check for you soon.
http://prnt.sc/ctnxjd
Regards,
Junnie4 years ago #1023374Hi, Thanks for contacting us. Please provide me link of your site and your admin account and FTP account via private message. I will check for you soon. http://prnt.sc/ctnxjd Regards, Junnie
To send a private message, just click on "Set as private reply" ?
That's right ?
Gorfou.
4 years ago #1023375In addition, when I activate NooMenu, my Beaver Builder page builder plugin does not activate anymore.
Thank you for your help.4 years ago #1023407Hi,
Wish you a nice day.
Sorry for my late responsive, our timezone is different from yours. when you were creating a topic, our daily time working ended.
Yes, You only need to check box Set as private reply. Only you and I can view your account
Junnie
4 years ago #1023450This reply has been marked as private.4 years ago #1023453This reply has been marked as private.4 years ago #1023529This reply has been marked as private.4 years ago #1023551This reply has been marked as private.4 years ago #1023622I'm sorry for this issue. There's a bug in our theme that causes the error with your theme's page builder. I fixed it on your site. And I'll add this fix to the next version of the plugin.
Kan4 years ago #1023744Hi,
Thanks for your efficiency, it works.
Question: Is it possible to give a color by link.
For example, the link on the home page is in blue, the link on the 2nd page is red, and so on.
If possible, how?
Thank you for everything.4 years ago #1023786Hi,
If you want menu color like this: http://prntscr.com/e9sahb then you can add Extra Class to the menu item: http://prntscr.com/e9sasi
We prepared some CSS class with this plugin:noo-bg-black noo-bg-blue noo-bg-yellow noo-bg-red noo-bg-gray noo-bg-green noo-bg-pink
If you want the different text colors for menu items. You will have to write CSS. For example, you add this CSS code with the class noo-text-red to the Advanced -> Custom CSS:
.noo-text-blue > a { color: red !important; }
Then you can use the noo-text-red as the Extra class similar to the above case ( http://prntscr.com/e9sasi )
Kan -
