NooTheme Premium WordPress Theme › Forums › Other Products › Noo Menu › noomenu mobile menu blank and weird css styling
- This topic has 20 replies, 3 voices, and was last updated 3 years, 1 month ago by
3 years, 4 months ago #1044063
hi there, i just renewed my support, im having problem with the menu and the mobile menu is blank. here is the link to the test site http://rapidsiteservice.com/rbspraytech/our-products/#
official site : rbspraytech.com/rbspraytech/our-products/# see the menu on the right ,
also the menu design looks strange the
- code seems to be repeating
3 years, 4 months ago #1044198Hi,
Thanks for contacting us and We are so sorry for late response.
Please give us your admin account privately via checking Set as private reply checkbox.
We will help you to check this issue.
Tracy
3 years, 4 months ago #1044232This reply has been marked as private.3 years, 3 months ago #1044571guys,
any updates ?
3 years, 3 months ago #1044722hello ? any updates?
3 years, 3 months ago #1044723Hi. Again.
Thank you for feedback us and sorry for the late response.
Can you give us admin permission for this account? We need to check menu struct and something config.
3 years, 3 months ago #1044728This reply has been marked as private.3 years, 3 months ago #1044729This reply has been marked as private.3 years, 3 months ago #1044795did you manage to login ?
3 years, 3 months ago #1044853Hi.
We have checked your site and found the conflict between our noo menu plugin & your theme.
We also added the custom CSS at file /wp-content/themes/blaszok/style_custom.css to help you fix that.
#mpcth_page_wrap #mpcth_sidebar ul li.menu-item:before { border-left-color: transparent; } #mpcth_sidebar ul li.menu-item { padding: inherit; } #mpcth_page_wrap .widget ul ul.mega-nav { padding-left: inherit; }
3 years, 3 months ago #1044854Thank you so much for the fix 🙂
i been trying to figure out how do fix this for sometime!
ok now this is out of the way 🙂 need another help now 🙂
pls check the site with mobile browser, the noomenu is not appearing.
3 years, 3 months ago #1045032This reply has been marked as private.3 years, 3 months ago #1045049This reply has been marked as private.3 years, 3 months ago #1045080Hi Again.
I have helped you show the menu on the mobile screen.
3 years, 3 months ago #1045083what was the problem ?
3 years, 3 months ago #1045085The issue from your menu config for mobile menu https://prnt.sc/gt268z
Jackie.3 years, 2 months ago #1046435This reply has been marked as private.3 years, 2 months ago #1047085guys, been 2 weeks,
any updates?
3 years, 2 months ago #1047108Hi Again.
We have fixed that issue on your site.
3 years, 2 months ago #1047114Hi there
could you advice me what caused the problem and how you fixed it ?
so i can keep track of it if any problem would to appear in the future
thank you so much
3 years, 1 month ago #1047315Hi again.
Because have some conflict CSS with your theme, we must add the custom CSS at customizer/additional CSS to help you fix the issue with your menu.
The class can be change when you put to another position or the theme.
Don't worry about that, you can contact us again. We will help you check that if have the problem.
