NooTheme Premium WordPress Theme › Forums › Timetable › Noo Timetable and BeautySpot – WordPress Theme
- This topic has 11 replies, 2 voices, and was last updated 3 years, 11 months ago by tinhbeng.
3 years, 11 months ago #1135025
Hello. Thank you for your plugin. I've been looking at it for a long time, and I finally bought it. I really hope you can help me with the settings. I thought it would be easy, but there's a couple of things to solve. Thank you in advance.
1. Please do support Gutenberg, there's no way to do it in the WordPress era without it now. Almost every plugin has support for Guttenberg. This is so critical that if I had known in advance that Noo doesn't have support for Guttenberg, I would have thought several times whether to buy or wait for you to make it. We didn't notice it right away - https://i.imgur.com/dbsg4wt.png. Sorry.
2. We use the theme https://themeforest.net/item/beautyspot-wordpress-theme-for-beauty-salons/8020062 and our attempts to implement Noo were unsuccessful. It turns out to be https://i.imgur.com/73VkqM7.png, and it turns out to be https://i.imgur.com/a07LLIh.png. For some reason, the plugin doesn't support the template style. Please help.
3 years, 11 months ago #1135862By the way, here is the page with NOO https://www.samtulana.ru/edu/.
I'm sorry, but you have been answering questions for a very long time.
3 years, 11 months ago #1135868Sorry for the delayed reply.
With Gutenberg you can create render shortcode from block class editor or you can then use the block shortcode and use the above text render.
NooTimetable currently uses its own template and does not use the style of the theme.
3 years, 11 months ago #1136652What is it? I can't send messages here.
3 years, 11 months ago #1136658Thank you for answering.
Let's take it in order. You're good at https://www.samtulana.ru/wp-admin/edit.php?post_type=page - https://i.imgur.com/YDXAJrg.png. Pages open properly, like https://www.samtulana.ru/noo-timetable-event/. Please come in and look, there's a headline, indents and so on - https://i.imgur.com/1Afq5C3.png.
By the way, this page does not open for me - https://i.imgur.com/aUdZIfc.png - here is the link https://www.samtulana.ru/noo-timetable-class/. Shows 502 Bad Gateway. Can't edit it either. Please help me.
3 years, 11 months ago #1136660Which begs the question, why does https://i.imgur.com/SMKccoU.png open like this https://www.samtulana.ru/classes/? What do you have to do, that it opens like this https://i.imgur.com/1Afq5C3.png? Can't we just make it open like this? Maybe this setting https://i.imgur.com/SMKccoU.png has a short code that you can paste into a page?
Also, pay attention to this page https://www.samtulana.ru/classes/community-class/. It is much worse here, because the site is completely broken. After all, there should be an output and normal display of pages, as on the site, for example, as this page https://www.samtulana.ru/mdbj4njcgx99j4oa/?
At the plugin itself everything is fine, but customization is frightening, because I thought that the plugin is easily inserted into the template in the form of shortscodes, as here you made https://www.samtulana.ru/noo-timetable-trainer/, and here is https://www.samtulana.ru/classes/community-class/ and you do not know how to fix it. It's quite possible that it's easy to do, so please help me.
3 years, 11 months ago #1136906What about Gutenberg, I don't have that - http://prntscr.com/seh9py. I have is this - https://i.imgur.com/B1FzPpg.png.
3 years, 11 months ago #1137613This reply has been marked as private.3 years, 11 months ago #1138003This reply has been marked as private.3 years, 11 months ago #1138016Hi,
You can use block "Classic" to add shortcode.
https://www.samtulana.ru/groupes/community-class/
- You need to add the custom CSS for it. Because they are being used template from Noo Timetable.
- You can change the class slug here: http://prntscr.com/sf8pye
3 years, 11 months ago #1138024Hello.
So, I have to edit the scripts in the plugin itself every time after updating the plugin?
Look at this - this is https://www.samtulana.ru/noo-timetable-event/ embedded. Why can't you make this page https://www.samtulana.ru/groupes/ and this https://www.samtulana.ru/groupes/pure-strong-yoga/ look the same? So, each of your customers changes the code in the plugin for themselves? Maybe there is some way out? Right now the plugin completely breaks our site. What can we do? Thank you.
3 years, 11 months ago #1140135Hi,
You can add custom CSS to style.css of Child Theme instead of Noo Timetable. This helps you don't need to update the code when updating the plugin.
This is the default class archive page. If you want to build a custom page you can use the Noo Class shortcode.
As I told you Noo Timetable uses its own template. If you want to custom for it, you can use Child Theme and customize the code for it
