Hi team support,
In my old version theme. I used the visual composer addon called "Noo Information"
https://nootheme.com/documentation/organici/ . Check the point 11 of the part visual composer
In the old version of my theme I could put on the description a link inside and the result in the home is a link
here the setting in the backend http://prntscr.com/h4plwv
here the result in the home http://prntscr.com/h4pmd4 or in the home https://www.amocomosoy.com/
But with the new version when I put a link inside the description, the widget just print the link and it doesn´t put a link as this addon did in the past. I tried to put html code inside the description but the widget clear my html, now just is possible to put text in this addon.
display after update here: http://prntscr.com/h4poop or http://dev-new-web.pantheonsite.io/
How can I put a link inside the widget "noo info" as I did in the past, to have link to other pages, if the widget is not compatible with html now.
Thank you for your time.
