Hi.
I have been having an issue with visual composer. I contacted visual composer support and they replied with the following in regards to my issue....
"The issue is because there is a Visual Composer related code present in your theme added by the theme author. You will have to get rid of it. We would advise you to do so with the help of theme author, otherwise you might loose the extra elements added by him. Once this is done, you can install the standalone plugin and it will work fine."
Hence why I am contacting you. If you could get back to me I would greatly appreciate it. I am up to the deadline on getting my site live and currently cannot complete any of the needed work. I truly appreciate your time and look forward to hearing from you.
