NooTheme Premium WordPress Theme › Forums › Organici › Multipe problems
- This topic has 16 replies, 3 voices, and was last updated 3 years, 9 months ago by
Junnie.
3 years, 10 months ago #1026331
The theme I am using is Organici. The website can be found here http://www.cookingalchemy.com/wordpress
1. The contact page, email that appears on the, map is not linked and I can not connect it using mailto. The website is a link but there is no code associated with it. http://www.cookingalchemy.com/wordpress/contact-us/
2. The cart and login buttons appear twice when using the fixed menu
http://www.cookingalchemy.com/wordpressThanks,
KIM
3 years, 10 months ago #1026411Im sorry, for #2, the cart login buttons appear twice on interior pages, not home.
http://www.cookingalchemy.com/wordpress/all-products/3 years, 10 months ago #1026480Hi.
Thank you for contacting us and sorry for the late response.
Can you give us your site admin account again?
We will help you check the config and fix the issue soon.
3 years, 10 months ago #1026575This reply has been marked as private.3 years, 10 months ago #1026577This reply has been marked as private.3 years, 10 months ago #1026581Hi.
Can you set admin permission for this account?
3 years, 10 months ago #1026585I have changed it to admin
3 years, 9 months ago #1027002Another issu, again with the html no registering is in the bottom fooder, the link RaznovDesigns.com highlights on rollover but there is no hand and it's not clickable, yet the HTML code in customerizer/footer is correct
3 years, 9 months ago #1027483Thank you for feedback us and sorry for the late response.
#2 We have removed cart icon in the navigation.
#1 The contact page you contact form 7 ( Form Contact ). To set up contact form, please go to contact form 7 and set up for this form.
Jackie.3 years, 9 months ago #1027550Thank you but I am not happy with the fixes for #1 and #2 is unresolved.
1. The login button still appears twice and in theory the cart button should be onscreen at all times. Can you make the top menu static on scroll action along with the main menu or remove the cart and login from the top menu and put them only on the main menu.
2, The contact page form is not in question. Please see the attached document, the email address I am referring to is in the green area. Also on that image the map title are the lattitude and longitudinal coordinates, can that be changed as well?
KIM3 years, 9 months ago #1027570Sorry for the mistake, we have helped you remove login/signup, cart icon on the top and put them only the main menu by changed something config on customizer.
If you want, you can change the icon for top bar at customizer/ header/ navbar top
And for navigation bar at customizer/ header/ navigation bar
2. With google map info, we can't change the top left info on the map, it auto generate from Google Map API.
Jackie.3 years, 9 months ago #10276432. What about the other issue from the screenshot, the email in the green section will not connect correctly. I tried adding the hmtl but it spits it out to the screen
3. Also, is there a way to set a header image by category for each product (butters, spices, ect) or must this be done manually?
3 years, 9 months ago #1027957Hi.
#2. I'm not sure about that. Can you explain more about email field in google map? This email address gets from your email field in noo map shortcode. What do you want with this email field? This just text content.
#3. If you want to have each page title image for each product, you need to input manually on product page settings.
Jackie.3 years, 9 months ago #1027998Still having a few issues:
1. The my-account page is missing the sign up form column and only the login form shows
my page: http://www.cookingalchemy.com/wordpress/my-account/
your example page: http://wp.nootheme.com/organici/my-account/2. link on the footer not working, html set in customizer is correct: Website by RaznovDesigns.com
3. this note is appearing on the dashboard:
Your theme (NOO Organici Child) contains outdated copies of some WooCommerce template files. These files may need updating to ensure they are compatible with the current version of WooCommerce. You can see which files are affected from the system status page. If in doubt, check with the author of the theme.4. the home page on scroll should show the cart/login buttons as it does on interior pages
3 years, 9 months ago #1028373I posted these issues last week, still have not received a response...
1. *** The my-account page is missing the sign up form column and only the login form shows
3 years, 9 months ago #1028405Hi,
Sorry for my late response.
Question 1: I edited for you http://prntscr.com/ewa2sv
Please go to admin panel/Woocommerce/Settings/Accounts and check box Enable registration on the "My Account" pageQuestion 2: I am checking this issue
Question 3: Please update to the latest version Of Organici theme to fix this issue
Question 4: You can setting in Customizer/Header/NavBar Top
Junnie
3 years, 9 months ago #1028407Hi again,
Question 2: I edited for you. Please check again
Junnie
