NooTheme Premium WordPress Theme › Forums › Organici › Logo problem since updating theme
- This topic has 13 replies, 3 voices, and was last updated 1 year, 6 months ago by
2 years, 3 months ago #1066022
I've noticed since updating the Organici theme on the following website that the logo now appears twice which didn't occur before - http://www.nutsabouthealth.com.au.
Any help to fix this would be appreciated.
2 years, 3 months ago #1066077Hi,
Please give us your admin account and FTP account privately via checking Set as private reply checkbox. We will check this issue soon.
2 years, 3 months ago #1066128This reply has been marked as private.2 years, 3 months ago #1066143Hi again,
You forgot to give us your admin account privately. Because we need to access your Dashboard to see your configuration.
2 years, 3 months ago #1066151This reply has been marked as private.2 years, 3 months ago #1066206Hi again.
Please check the WP-admin account. We get the error message when using that account.
INSECURE PASSWORD: Your login attempt has been blocked because the password you are using exists on lists of passwords leaked in data breaches. Attackers use such lists to break into sites and install malicious code. Please reset your password to reactivate your account. Learn More
2 years, 3 months ago #1066207We also checked the source code to help you fix the issue.
2 years, 3 months ago #1066212This reply has been marked as private.2 years, 3 months ago #1066233I've noticed it's fixed now. Thank you for your assistance.
Could you please let me know if this was due to an error by me or was it an issue with the recent theme revision?
Thanks again.
2 years, 3 months ago #1066299Hi again.
Yes, the issue from our CSS style has changed.
We have fixed that issue. It will include in the updated version.
Don't worry about that.
Jackie.1 year, 6 months ago #1079961This issue has just reoccurred after I updated the Organici theme to a new version in my site and it has returned to showing the two logos side by side again.
What can I do to correct it?
1 year, 6 months ago #1079962Just an update on this. I am able to get the logo displaying correctly when I set the NavBar Position to Static Top but two logos appear side by side when it is set to Fixed Top.
1 year, 6 months ago #1080042Anyone there?
1 year, 6 months ago #1080126Hi again.
I have enabled the fixed navigation on your site, but only one logo appears. Maybe you have fixed that issue.
Please check it and let us know again.
