NooTheme Premium WordPress Theme › Forums › JobMonster › Job Sidebar Widget Reset button doesn’t work on “Keyword Search” field
- This topic has 6 replies, 2 voices, and was last updated 1 year, 1 month ago by Jackie.
1 year, 1 month ago #1220009
Hi Jackie,
I found a small bug on the job search widget.
In the following setting in Job Sidebar Widget (/wp-admin/widgets.php),
Disable Live Search (Ticked)
Enable Reset Button (Ticked)
Hide Search Button (Unticked)the "RESET" button on /jobs/ doesn't work for "Keywords Search", although other dropdown fields can be reset successfully.
Please test by entering some keywords and pressing the reset button.
For website and Admin access, please refer to quote #1219923
Thank you!
1 year, 1 month ago #1220020Hi.
I have fixed that issue on your site. Now you can use the reset button for the keyword search.
I have changed the source code in this file: /wp-content/themes/noo-jobmonster/widgets/widgets.php line 1750.
1 year, 1 month ago #1220026Thank you very much Jackie for your prompt reply!
It's fixed the issue.Hey, I can't remember how many but there have been quite a few things I have raised up and you have fixed within parent theme.
I am wondering if these are all noted on your side and the next theme update includes their fix.If so, I can just replace the parent theme files without any worries but, if not, I still have to replace one file and another (I still keep all the notes on which files I have replaced in the parent theme folder) so that updated files (by you like this time on parent theme) won't override the modified files in the parent theme.
Also, I would like to know the full list of what is modified in the new update. Not line numbers as such details but reasons of fix (update the files) etc. Otherwise, it would be hard for me to replace the parent theme folder with the new one.
I want to hear your thought on this. I know it's troublesome but is there some way to make it easy?
Have a good weekend.1 year, 1 month ago #1220030Hi.
Thank you for your feedback.
Yes, I have fixed all the issues as you report to our theme, and it will include in the next version. Can you give us a note about the change on your site? We will summarize the note and check the theme to avoid missing the update.
1 year, 1 month ago #1220038This reply has been marked as private.1 year, 1 month ago #1220039This reply has been marked as private.1 year, 1 month ago #1220045Thank you for your message. I'll check and review our theme to avoid missing the issue on the update.
