NooTheme Premium WordPress Theme › Forums › Emigo › Issues with fixed header.
- This topic has 19 replies, 4 voices, and was last updated 3 years, 2 months ago by
Bryan.
3 years, 4 months ago #1044054
Hello!
When I use a fixed header, all the page breaks, something like a padding or margin is missing: http://prntscr.com/gj2qwb
Can you check it out please?
Best, Jorge
3 years, 4 months ago #1044097Hi, Jorge
Please give us your website's URL and admin account privately via checking Set as private reply checkbox.
We will check, then feedback you soon.
Tracy
3 years, 4 months ago #1044126This reply has been marked as private.3 years, 4 months ago #1044156Hi again,
We have got access your website then choose 2 cases of Navigation Bar section, they work normally so we don't get the issue. Please check again, then describe your question by the images.
We will help you to check soon.
Tracy
3 years, 4 months ago #1044249Hello,
take a look here: http://prntscr.com/gkryl4
And here: http://prntscr.com/gkryrs
Thanks for the help!
3 years, 4 months ago #1044294Hi again,
This is the default when you choose Fixed Top on NavBar Position. There are 2 ways which you can choose:
1 - If you still want to use NavBar Position: Fixed Top >> we will help you add a Custom CSS segment to put the content down.
2 - You can choose others NavBar Position for your website.
Please check, then let us know your opinion. We will help you to check.
Tracy
3 years, 4 months ago #1044415Hello!
Yes my client is asking for the fixed top header, can you give the snippet for this to work?
Best, Jorge
3 years, 4 months ago #1044519Hello!
Do we have any update on this? This is urgent for my client.
Best, Jorge
3 years, 4 months ago #1044534Hi again, Jorge
Thanks for your feedback and We are so sorry for late response.
We have got access to your website then change the Header to Fixed Top (not support for page product slider) but nothing to change. It seems that your server saves the cache. Please help us to contact provider hosting to delete your cache. Then give us your FTP account privately.
We will check, then help you soon.
Tracy
3 years, 4 months ago #1044552This reply has been marked as private.3 years, 4 months ago #1044649Hello guys,
It is urgent for my client that we fix this ASAP, do we have any update?
Best, Jorge
3 years, 4 months ago #1044657Hi.
Thank you for feedback us and sorry for the late response.
We have added some CSS to help you fix the issue with header fix top option.
3 years, 3 months ago #1045286Hello Jackie!
Thanks for the help! We just noticed that when the user scrolls down, our logo gets a little bit covered at the top:
Can you take a look again please?
Best, Jorge
3 years, 3 months ago #1045387Hello!
Is there any update on this?
Best, Jorge.
3 years, 3 months ago #1045590Hi.
Thank you for waiting for us.
We have fixed that issue on your site.
3 years, 3 months ago #1045613Thanks! Works amazingly.
Best, Jorge
3 years, 2 months ago #1046257Hello!
I have the same issues but now with the mobile version, can you check it again please?
Best, Jorge
3 years, 2 months ago #1046411Hello!
Is there any update on this one please?
Best, Jorge
3 years, 2 months ago #1046714Hello once again,
I'm still having issues with the mobile header. Can you check it again please?
Best, Jorge
3 years, 2 months ago #1046830Hello
I have quick fixed the logo problem for you on safari.
Please check again.
