NooTheme Premium WordPress Theme › Forums › JobMonster › I need help by import of jobs and companies via CSV
- This topic has 6 replies, 2 voices, and was last updated 3 years, 10 months ago by dangdv.
3 years, 10 months ago #1186670
Hello dear Noo team,
I have already read many topics about job import here. It is very important for me because I have to upload many jobs and companies via CSV.
I have already installed the recommended plugins "WP All Export and WP All Import", but I cannot do it alone and I need your help. There is of course a tip for good work.
Three things are very important to me:
- I need a CSV template for importing jobs and companies.
- It would be very good if a company was also imported and created during the job import.
- If multiple jobs are uploaded by the same company, there should be a match. In this case, two company profiles should not be created.
I have created a CSV scheme with all the important information that must be included in the template.
I look forward to your support and I am available for any questions.
greets,
Silvermann
You must be logged in to view attached files.3 years, 10 months ago #1189158Dear, I don't have CSV template for import job data, but you can create it. Please add new one job then use WP Export to export it then you can use it as template.
3 years, 10 months ago #1189162<span>Don't you want to help me?</span>
3 years, 10 months ago #1189164You can log in with access data in the backend and create a template.
3 years, 10 months ago #1189829You can use WP All Export plugin to export one Job to use as template, You can't do it ? Please kindly send for me admin account your site and your site URL via private reply, i will check details to help you.
3 years, 10 months ago #1190770This reply has been marked as private.3 years, 10 months ago #1192881 -
