NooTheme Premium WordPress Theme › Forums › LandMark › I Have a translation problem and want to change posts hover color
- This topic has 24 replies, 2 voices, and was last updated 2 years, 1 month ago by
_nixstar_.
2 years, 4 months ago #1061012
I Can't translate "call us now" with loco translate on the element "noo hotline".
I want to translate on the property sidebar in "RP - advanced search property" the word "all" and the button text "Search". It's not working too with loco translate.
And if that is possible I want to change the hover color of the posts on "noo blog masonry" layout style "creative". I don't find how can I do this.
Thanks for your help,
2 years, 4 months ago #1061039Hi,
We still translate "CALL US NOW" in Noo Landmark theme language, and All. Search text in Realty Portal plugin. Please check it again.
For your blog hover color, please give us your link directly and admin account privately. We will check it, then feedback you soon.
2 years, 3 months ago #1061687This reply has been marked as private.2 years, 3 months ago #1061737Hi again,
Your admin account doesn't correct. Please check it again.
In addition, we also click all your link but they aren't activated.
You should check all again, then feedback us.
2 years, 3 months ago #1061759This reply has been marked as private.2 years, 3 months ago #1061780Hi,
1- We have got access to your website then found that you have translated "Call us now" text successfully. See this image: https://prnt.sc/l16xnh and https://prnt.sc/l16y0s
2- We also found "All" text in Realty Portal plugin, you can translate normally: https://prnt.sc/l16ys2
3- We don't see any issue about translation in this page:https://prnt.sc/l1703g
Please give us the described image to clear this issue.
4- compare text is translated successfully: https://prnt.sc/l171co
Please hover compare button on front page to check it.
5- What the exact color do you want to change for hover price?
Please check, then describe your question as clearly as possible if you get other points.
2 years, 3 months ago #1061929This reply has been marked as private.2 years, 3 months ago #1061963Hi again,
1- We opened your link but the text "call us now" was translated. Can you please give us the described image about your issue? It will help us to understand your question.
2- We also access to your website and found "All" text but you haven't translated yet. In this case, you should find this text in Realty Portal plugin, you can see this image: https://prnt.sc/l3g6n0
With these texts as listing types, etc you can find in Realty Portal: Advanced Search plugin
3- You can add this Custom CSS segment in Customizer > Additional CSS to change the price hover color:
.noo-list-property .noo-property-item-wrap .noo-action .property-price:hover {
color: #8e6b31;
4- Can you provide us with your image? Because we don't understand your question.
5- You can find this page in Realty Portal: Compare plugin.
2 years, 3 months ago #1061992This reply has been marked as private.2 years, 3 months ago #1062038Hi again,
1- We can find this text in Noo landmark core 2 plugin so you can translate it.
2- We checked on your website and our website and found this is the custom fields so you need to you WPML plugin to translate. If you have only 1 language you can find this text in this file: {root}/wp-content/themes/noo-landmark/includes/realty-portal/shortcode/map.php line 39
3- We also added this Custom CSS segment to help you:
.noo-list-property .noo-property-item-wrap:hover .noo-action .noo-price, .noo-list-property .noo-property-item-wrap:hover .noo-action .property-price {
color: #8e6b31;
4- We added this Custom CSS segment to help you:
.hentry.grid .blog-item .content-featured .content-thumb:after, .hentry.list-2-column .blog-item .content-featured .content-thumb:after, .hentry.list-single .blog-item .content-featured .content-thumb:after{
background-color:#3a3738;
2 years, 3 months ago #1062159This reply has been marked as private.2 years, 3 months ago #1062216Hi again,
1- You can go to {root}\wp-content\plugins\noo-landmark-core\admin\vc_extension\shortcodes\noo-hotline.php line 35 to change this text directly.
2- This above only corrects for your price. Social networks will be applied to another custom code. Please give us your link directly, we will help you to check it.
2 years, 3 months ago #1062414This reply has been marked as private.2 years, 3 months ago #1062417This reply has been marked as private.2 years, 3 months ago #1062444Hi,
If you have the knowledge about PHP you can change in this file {root}\wp-content\plugins\noo-landmark-core\templates\property\single-property\box-meta.php
2 years, 3 months ago #1062467This reply has been marked as private.2 years, 3 months ago #1062579Hi again,
You can use this Custom CSS segment:
.noo-list-property.style-grid .noo-property-item-wrap .noo-action-post .noo-property-sharing .noo-social-property i:hover:before, .noo-list-property.style-grid .noo-property-item-wrap .noo-action-post .noo-property-sharing .rp-social-property i:hover:before{color:#8e6b31 !important;}
2 years, 3 months ago #1062604This reply has been marked as private.2 years, 3 months ago #1062609Hi again,
We helped you to add this Custom CSS to hide this section, it works fine:
.noo-property-item-map .noo-info {
display: none;
2 years, 2 months ago #1063645This reply has been marked as private.2 years, 2 months ago #1063667Hi again,
Please make sure that you have the featured properties because this field will get the featured property to display.
You should check it carefully then feedback us.
2 years, 2 months ago #1063755This reply has been marked as private.2 years, 2 months ago #1063776Hi again,
You can try to use this Custom CSS segment to fix:
.noo-featured .noo-featured-main .noo-view {
margin-right: 513px;
margin-bottom: 129px;
2 years, 1 month ago #1064768This reply has been marked as private.2 years, 1 month ago #1064853Hi again,
Please tell us which screen resolution are you using to check this issue?
Because we also access to your website then checked it on other screen solution but everything works fine.
You should check it again, then feedback us.
