NooTheme Premium WordPress Theme › Forums › Timetable › Daily view not showing all classes
- This topic has 5 replies, 2 voices, and was last updated 2 years, 9 months ago by Thessa_v.
2 years, 10 months ago #1213337
I have multiple timetables on my client's website but I have some trouble showing the right content. The single class pages aren't used, we only use the popup to show content. On desktop we use the weekly view, on mobile the daily view because it's not possible to see the class popup on mobile while using the weekly view.
We noticed that not all classes are displayed in the daily view, but I can't seem to find the problem. Below you can find the used shortcodes:
Mobile: [ntt_schedule default_view="agendaDay" item_limit="0" min_time="9:00:00" max_time="22:00:00" class_cat="7,8,9,10" hide_time_range="12,13,14,15,16,17" show_time_column="no" show_category="yes"]
Desktop: [ntt_schedule min_time="9:00:00" max_time="22:00:00" item_limit="0" hide_time_range="12,13,14,15,16,17" class_cat="20,21,22,23,24"]
Good to know: we only display one timetable per page, the mobile timetable is also only loaded when a mobile device is detected.
Could you please tell me what I'm doing wrong?
Thanks in advance!Kind regards,
ThessaAttachments:
You must be logged in to view attached files.2 years, 10 months ago #1213346This reply has been marked as private.2 years, 10 months ago #1213356This reply has been marked as private.2 years, 9 months ago #1213391Hi,
Can somebody follow up on this?
Kind regards,
Thessa2 years, 9 months ago #1213404Dear, I have check your timetable on https://meirdam.be/ I see the table on mobiel is hidden, please show it.
And i please kindly give me more details your problem, your mean: the popup not work on mobile ?
2 years, 9 months ago #1213405Hi,
The timetable with weekly view is indeed hidden on mobile, but is replaced by a timetable with daily view (this only happens when a mobile device is detected)
The problem is that not all classes are showing, but I noticed that on desktop also not all classes are showing.
Kind regards,
Thessa -
