NooTheme Premium WordPress Theme › Forums › Palazzo › Customize print product sheets
This topic contains 6 replies, has 3 voices, and was last updated by Tracy Bui 1 year, 2 months ago.
1 year, 2 months ago #1060483
hello, I want to customize the presentation of product sheets for printing.
Reduce the size of the photo.
Add the product reference.
Thanks for your help.1 year, 2 months ago #1060589Hi.
To custom the Print property layout, you can check the source code at this file
wp-content/plugins/realty-portal/templates/property/print-property.php
1 year, 2 months ago #1060711Hello, thank you for your answer.
I would absolutely like to have the whole on a single printed fawn
I would like to add the reference of the propertyI send you the presentation that I currently have and the one I wish to have "aproximativement".
Maybe 'could you tell me which codes to change?
thank you in advance
You must be logged in to view attached files.1 year, 2 months ago #1060714New "approximate" print format desired
You must be logged in to view attached files.1 year, 2 months ago #1060734Hi,
We can understand your question and this is a customize question so we are so sorry we cannot help you directly. If you have a knowledge HTML&CSS and PHP code you can change in {root}/wp-content/theme/noo-palazzo/property/single-property/ single-property-content.php
We are so sorry for any inconvenience and thanks for your understanding.
1 year, 2 months ago #1061009Thanks for your answer but it does not seem to work with a child theme.
Can you help me?
1 year, 2 months ago #1061046Hi again,
We are really sorry but you need to check by yourself. Because it is out of our support policy.
