NooTheme Premium WordPress Theme › Forums › Emigo › Change product images
- This topic has 8 replies, 3 voices, and was last updated 3 years, 2 months ago by
jorgecastro91.
3 years, 2 months ago #1046258
Hello!
I want to use a custom plugin to show the single product images but can't seem to disable your carrousels, can you help me out to disable them? Since right now if I activate my plugin, it works correctly but your images are shown at the right.
Thanks! Best, Jorge
3 years, 2 months ago #1046272Hi,
You can use this Custom CSS segment to hide:
.noo-woo-all-images-wrap{display:none;}
We helped you to turn on your plugin and hide our carousel. it works fine
Tracy
3 years, 2 months ago #1046354Hello!
I'm sorry, but for SEO purposes I need not only just hide them, but no prevent them from being rendered, how can I do this?
Best, Jorge
3 years, 2 months ago #1046388Hi again,
We only use the Custom CSS segment on front-page, product images still display on the Dashboard.
It will help you can use the SEO purpose normally.
Tracy
3 years, 2 months ago #1046406Hello,
No, sorry. I mean that I need to prevent to be rendered on the page completely, right now they are being rendered but hidden with CSS, need to stop that.
Thanks for the help!
3 years, 2 months ago #1046539Hi Again.
Thank you for feedback us.
We have to remove the default product image gallery of Emigo theme on your site by removed the code at file
wp-content/plugins/noo-emigo-library/framework/woo_extensions.php line 30
3 years, 2 months ago #1046549Hello Jackie!
Awesome, thanks for the help! Is there a way I can modify this from the child theme instead of directly on the plugin code, so is update-safe?
Best, Jorge
3 years, 2 months ago #1046580Hi.
The code in our plugin, you can't overwrite the code via the child theme.
Please note the change when update our theme to avoid losing.
3 years, 2 months ago #1046713Oh ok. Thanks for the help!
Best, Jorge
